Reply
WGR614v9 Resetted-Default Security Key?
Bish
Resetted to factory settings as I was going to secure it up and change the channel for a new laptop.
But I can't use my old security key as it was resetted just wondering what the default security network key is?
Message 1 of 5
jmizoguchi
Virtuoso
Re: WGR614v9 Resetted-Default Security Key?
look BOTTOM of the router for default router interface
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
Bish
Plus how to change that security key when wireless connection has been setup
Message 3 of 5
Bish
Tried default access but can't connect through router so can't get to the routerlogin.net interface.
Message 4 of 5
jmizoguchi
Virtuoso
see router reset on my sig below.
you have not done reset correctly
you can setup wireless encryption once you can login the router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 5
Discussion stats
  • 4 replies
  • 4383 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
