Reply
WGT624 - Settings reset themselves.
elevate
Follower
No matter what I change on my router, the settings go away the moment you click off and log back in. Gimme some ideas on how to fix it (besides resetting and unplugging the router).
Message 1 of 2
jmizoguchi
Virtuoso
Re: WGT624 - Settings reset themselves.
Sounds like NVRAM in the unit is going bad. RESET is must for sure but if reset does not fix it then I would suggest to get new router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2035 views
  • 0 kudos
  • 2 in conversation
Announcements
