Reply
WNA1100 - Keeps Scanning
curlyq
Novice
I have just installed the WNA1100 Wireless USB adapter on my XP pc and it connects to the internet, but the Netgear icon in the system tray shows that it is still scanning for the network (red screen). If you right click on the connection icon in the system tray and click on Repair or open the Netgear Wizard, click on the Network tab and let it scan, the process will complete (green screen). Everything stays fine until you shut the computer down and restart, then it goes back to scanning again. I'm not sure what this means because it has found the network since I can connect to the internet - but somehow the startup scan isn't able to finish and show itself as complete. I've re-installed twice, but the same result. Any suggestions? Thanks.
Message 1 of 2
jmizoguchi
Virtuoso
Re: WNA1100 - Keeps Scanning
wna100 is NOT router .
it is adapter ...
belongs
http://forum1.netgear.com/forumdisplay.php?f=25
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3148 views
  • 0 kudos
  • 2 in conversation
Announcements
