Reply
WNDR-3700v2 firmware change of gui!
ToddeSwe
Tutor
Hi
The firmware in my WNDR.3700 v2 before the last one available had another nicer GUI but was removed when the last update was flashed.
Can someone tell me what was wrong with this firmware with th nicer GUI and why it was removed?
ToddeSwe
Message 1 of 10
Accepted Solutions
mbob4568
Guide
Re: WNDR-3700v2 firmware change of gui!
The firmware that had the modern GUI was V1.0.0.36 and is no longer available for download. I'm running it with no problems and I, like you,prefer the Genie interface as opposed to the old style GUI in V1.0.1.14 The current firmware has no reboot router botton and is missing a few other options that were in 1.0.0.36. If you would like 1.0.0.36 let me know and I could post if for you.
Message 6 of 10
All Replies
ElaineM
NETGEAR Employee Retired
Hi @ToddeSwe,
What firmware version you are referring to? From firmware version to what version?
ElaineM
NETGEAR Community Team
Message 2 of 10
ToddeSwe
Tutor
The version before V1.0.1.14 i don't have the versionnumber of that one but i know it was the version before the one i have now because i've just updated twice that one i speak of and from that one to this one i have now. Smiley Happy Do you follow?! Smiley Happy he he he
Message 3 of 10
ElaineM
@ToddeSwe According to engineering, there is nothing wrong with the firmware. They just updated the smart wizard GUI to take advantage of additional features and consistency the product.
ElaineM
Message 4 of 10
ToddeSwe
Tutor
No there's nothing wrong with it but the gui changed to a more nicer one for a while then it went back to where it is now.
Message 5 of 10
mbob4568
Guide
Message 6 of 10
ToddeSwe
Tutor
Hi and thanks!!
Yes please if it's not bad in some way? What have changed in the newer version? Please tell me where i can fetch it. Smiley Happy
Message 7 of 10
mbob4568
Guide
ToddeSWE
Sent you DM with link
Message 8 of 10
ToddeSwe
Tutor
Anyone knows what's changed from this version to the latest one?
Message 9 of 10
mbob4568
Guide
If I recall it fixed a minor security bug. Nothing major expect for leaving out a reboot button as well as no wireless AP function, and a downgraded GUI. As far as I'm concerned, the current firmware is not finished.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3542 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
