Reply
WNDR300 Seriously bricked?
vefferdk
Hi folks!
I wanted to update my wndr3700 router yesterday thru the 192.168.1.1 site (wireless (big fault i figured))
It failed, and the power is now blinking slowly green.
I then googled a lot, and so far i have tried:
Netgear recovery utility, with 30-30-30 reset, reset power off, hold and release.
Then i have tried the TFTp2.exe app, to transfer the latest non beta software - it fails every time.
I tried using the tftp in terminal (mac) but i keep getting an error when using the:
Verbose
bin
Put (wndr3700 software.img)..
I'm not sure what to try next, please help Smiley Sad
thanks!
Message 1 of 7
sabretooth
Apprentice
Re: WNDR300 Seriously bricked?
Yeah you certainly didn't follow the instructions but doing it wired only.
Try these methods to attempt recovery.
http://www.lancelhoff.com/how-to-fix-a-bricked-linksys-router/
or
http://www.savemondo.com/2008/11/21/how-to-unbrick-a-linksys-router/
Message 2 of 7
vefferdk
well technically there were never no warning on the ip address saying i should go wired- otherwise i would have done - but thanks, ill take a look at the methods.
Message 3 of 7
vefferdk
i get an error in cmd, when typing the tftp line, it says that tftp was not recognized as an internal or external command - any clue?
Message 4 of 7
jmizoguchi
Virtuoso
http://forum1.netgear.com/showthread.php?t=30453
if follow this and still fails then one other choice is jtag
go to myopenrouter.com and you will find some info there.
othere wise unit is dead
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 5 of 7
sabretooth
Apprentice
I downloaded the firmware and it says to read the Release Notes first. I found this for you in the release notes.
To Install
Note: Do not upgrade the firmware using a wireless connection. Please perform firmware upgrade with “wired” or Ethernet connection only.
Message 6 of 7
jlewter
Guide
Hold down the reset button until the led starts blinking yellow, KEEP HOLDING IT DOWN for a while until the blink becomes constant (dont just let go on the first flash).. There is a TFTP window you can hit when it boots up and it's harder to do than holding down the button for a long time that will put it in a perminate TFTP listen mode.
That is, if we are talking about the 3700.
I REPEAT, Wait until the LED is flashing orange constantly...
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5399 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
