Reply
WNDR3300 dropping connection.
pinoy_92
Novice
ive been seeing this problem a lot in many netgear products, not just the router im using. quite frankly its getting really irritating.
im using WNDR3300.
Firmware Version V1.0.45_1.0.45NA
and im using windows 7 ultimate 64bit.
please help cuz im really close to using a hammer to fix this s2pid thing.
Message 1 of 3
pinoy_92
Novice
Re: WNDR3300 dropping connection.
bump..................
Message 2 of 3
MKeezy
Novice
You may want to make sure that you have the latest firmware update for your router model. I had the same issue, and it turns out that I just didn't have the firmware version update that fixes Windows 7 compatibilty issues. You might want to download all the firmware updates NetGear has released for your router and reapply them starting with the earliest firmware version to the latest. Make sure you are Hard Wired via Ethernet to the router during the update process.My router has had a total of four firmware updates, which I reapplied, layering them onto the router one at a time. I am now using my, once thought to be useless WNDR3300-100NAS rotuer again with Windows 7 and no more problems. If you have the same router that I do, you'll need to download updates WNDR3300_V1.0.26_1.0.26NA, WNDR3300_V1.0.27_1.0.27NA, WNDR3300_V1.0.29_1.0.29NA, and last, but not least WNDR3300-V1.0.45_1.0.45NA firmwareupdate version files. Just save them somewhere on your PC, connect your router via Ethernet, login to your router, and manually apply each of the udates to it. The most recent firmware update (WNDR3300-V1.0.45_1.0.45NA) resolves Windows 7 compatibility issues that exists with some of these routers. They were initially designed to be capatible with only Windows versions up to Windows Vista.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2628 views
  • 0 kudos
  • 2 in conversation
Announcements
