Reply
Highlighted
Follower
WNDR3400 and WD Mybook
I cannot get tge WNDR3400 router to recognize my WD usb 750g Mybook drive. The only way I can access it is throught the http. I want to see it on my network.
Message 1 of 2
Highlighted
Re: WNDR3400 and WD Mybook
make sure under advanced USB setting, check the Access Methods that you want to use. If you want to use UNC make sure the Network Connection is enable \\readyshare.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3119 views
  • 0 kudos
  • 2 in conversation
Announcements
