Reply
WNDR3400 v2 wireless settings
kdbarnard
Follower
I want to set router to "turn off wireless signal by schedule".
Firmware VersionV1.0.0.54_1.0.82
I am on the Advanced Wireless settings page ant the option to set it is there but thhe function buttons are grayed out and not functional so I cannot "add a new period" .
What am I missing?
I have set the router LAN TCP/IP setup to a 192.168.1.254 and unchecked "use router as dhcp server" to use it as a second wireless hotspot on my netwwork and it is working fine for that. I just cannot set the period that wireless is off.
Model: WNDR3400v2|N600 Wireless Dual Band Router
Message 1 of 2
antinode
Guru
Re: WNDR3400 v2 wireless settings
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Advanced
Wireless Settings" and "AP Mode".
   No bets, but with the router configured as you did it, it might not
be able to contact a time server, and its inability to get the date+time
might cause it to disable its scheduling features.
   > What am I missing?
   Familiarity with "Chicago" lyrics?  Web search: "Does anybody really
know what time it is?"
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 344 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
