Reply
WNDR3400v2 connection problems
tokie
Follower
I didn't see a section for wndr3400 so i posted it here.
Ok so here's my problem:
My router is working fine. My wireless is working fine. I fixed my old desktop and decided to hook it up via ethernet (no wifi adapter at the moment). So after that, no more wifi. =( Am i missing something here? I checked all the configurations and I've tried resetting everything but the desktop is the only thing that has internet. After turning off the desktop, the wifi works again.
note: for some odd reason my laptop was fine. it was my phone, wii, etc that wouldn't connect properly. they would connect then disconnect.
Message 1 of 2
jmizoguchi
Virtuoso
Re: WNDR3400v2 connection problems
sounds like dead internal wireless or bad power supply.
if power supply not putting out correct voltage wireless can die since it uses more than simple wired router.
if still the same I say you got brick unit
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3814 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
