Reply
Highlighted
Follower
WNDR3400v3 - Readyshare works fine, but now I can't plug in my hard drive directly
Okay, I just purchased the WNDR3400v3 with the latest firmware. I setup Readyshare for my external hard drive I use for everything. It is the Western Digital, My Passport for Mac. I setup everything just fine on the Readyshare, and it continues to work.
My issue is, now when I plug in my WD My Passport into my Mac, it does not read. I have a feeling the router reformatted the hard drive, or changed the permissions. I have no idea how to have it so I can view it on my computer again.
How would I go about viewing it on my computer again when I need to plug it in, but also having it work on my Readyshare?
Message 1 of 2
Highlighted
Virtuoso
Re: WNDR3400v3 - Readyshare works fine, but now I can't plug in my hard drive directl
Check the partition type in HD
Likely you will need reformat again
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Discussion stats
  • 1 reply
  • 3532 views
  • 0 kudos
  • 2 in conversation
Announcements
