Reply
WNDR3400v3, bridge mode?
jchacon
Follower
I've got a Motorola SB6120 with my WNDR3400v3 hooked up to it. I've also got a Motorola SBG6580. I would like to bridge the modems together in order to double my internet speed. How do I go about doing this, and is it possible with what I have?
Installer at Northland Communications | www.yournorthland.com
Message 1 of 2
TheEther
Guru
Re: WNDR3400v3, bridge mode?
If you were hoping to join both modems to make one fat pipe to the Internet (i.e. load balance), then that's not really possible with what you have. There are hacks that you can try on a PC with dual NICs or with static routes but they are clunky.
Your best bet is to install a router with support for load balancing. These are usually considered business-class products. Do a web search for dual WAN router. You'll find models from the major brands that are less than $150.  Even Netgear has a few options. Here is an article from smallnetbuilder.com that might be helpful.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3612 views
  • 0 kudos
  • 2 in conversation
Announcements
