Reply
WNDR3700 Randomly drops connection
HappyRadio
Hello.
My router keeps dropping me from my internet connection. Usually I would browse the web, or use software that requires an internet connection, it would be fine for around 15-20 minutes, but after a while my network would just be a "Local Only" connection, and I would be unable to use the internet. This has been going on for months and I can't seem to find out what's causeing this. If someone could be kind enoughj as to try and help me find out what's wrong, that would be great, thanks!
Hardware Version WNDR3700
Firmware Version V1.0.7.98NA
GUI Language Version V1.0.0.64
Message 1 of 11
jmizoguchi
Virtuoso
Re: WNDR3700 Randomly drops connection
both wired or wireless. Test both if you are only using wireless
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 11
madhatter
Apprentice
I would recommend upgrading to the latest f/w. Follow the instructions carefully. Don't skip any steps. If there is still a problem after the upgrade the use the Erase function to reset the browser back to factory settings and rekey your setup.
1xRBR50 1xRBS50 2xRBS40
Message 3 of 11
JimmyJ
i had the same problem and tried different settings and firmwares with no luck then tried V1.0.4.68NA and have had no problem since
Message 4 of 11
HappyRadio
Hmm...Well, this is strange. I tried upgrading to a new firmware but there was "No New Firmware Version Availabe". Is V1.0.7.98NA the latest firmware version, then?
Message 5 of 11
jmizoguchi
Virtuoso
you always to want to go support.netgear.com and manually look the available firmware.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 11
madhatter
Apprentice
I assume you are on a WNDR3700 V1 router:
Go to http://downloadcenter.netgear.com/en/product/WNDR3700v1
you will find:
Firmware Version 1.0.16.98 (North America only)
Firmware Version 1.0.7.98 (North America only)
Firmware Version 1.0.4.68 (North America)
Firmware Version 1.0.4.55 (North America)
Firmware Version 1.0.4.49 (North America)
Firmware Version 1.0.4.31 (North America)
Message 7 of 11
JozefTylor
After a long rainy day, My america vpn is desplaying troubles during working. Its signals are low and have to take closer to pc.
Message 8 of 11
HappyRadio
Hi everybody, and thanks for your help, but i've been upgrading and downgrading to all kinds of different firmwares, but that doesn't seem to be fixing the problem. Are there any other feasible solutions that you guys suggest trying out?
Message 9 of 11
madhatter
Apprentice
You did not answer whether or not your problems are occurring on a wired or wireless connection. If wired, then
1) update your nic card driver
2) replace the cable that runs from the router to the modem
3) substitute the modem
4) monitor your ISP's quality
In addition, if Wireless
1) Update wireless adapter
2) substitute your adapter
3) change the wireless channel on your router
4) check signal strength between the adapter and the router
Message 10 of 11
fogshat
don't know if this helps, but i had that same problem with a kindle, but once i put the mac from the kindle into the router the connection is always there.
Message 11 of 11
Discussion stats
  • 10 replies
  • 6535 views
  • 0 kudos
  • 6 in conversation
Announcements
