Reply
WNDR3700 port forwarding
greg888
Novice
I'm trying to connect two servers to my WNDR3700 router. One to port 80, the other to 8080.
The one to port 80 works perfectly. I can access the server externally from the internet with my ISPs ip+:80
I cannot get 8080 to work. I've set it up exactly the same as the 80, port forwarding to the servers local ip. I can access the server with the local ip, but I can't access it from the internet with my ISPs ip+:8080.
I've used an online port scanner to check it, but it says "Connection Refused".
Any ideas?
Message 1 of 7
jmizoguchi
Virtuoso
Re: WNDR3700 port forwarding
Port 8080 is used by router's remote management. You may able to change the ports on remote management yet using 8080 has been has an issues
use other than 8080
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 7
charm
Novice
it's because port 80 is one of the most common/accessble port. Please try other ports like SMTP (TCP port 25), Telnet (TCP port 23).
it takes a valid connection to communicate
Message 3 of 7
jmizoguchi
Virtuoso
Port80 can be block by ISP so check with them first
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 7
greg888
Novice
Thanks for your help. I changed to another port number, and it's all working now.
Thanks again.
Message 5 of 7
jmizoguchi
Virtuoso
Sounds great.. Enjoy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 7
charm
Novice
happy to hear that!!!
ENjoy! 🙂
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4605 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
