Reply
WNDR3700v3 having problems connecting both wireless and wired
pam1374
Follower
Hi all,
I'm hoping someone here has an idea on how to fix the problem I'm having. I just got the N600 modem today, and have updated to latest firmware V1.0.0.22_1.0.17 (updated during installation). I can connect my laptops/iPods wirelessly without issue, but when I go to also plug the ethernet cord that connects to my TV (I have a Vizio that will run Netflix through it directly without a Roku box or similar), suddenly my connection from the router to the DSL modem will disconnect or something. I have also experienced this if I tried to hardwire a laptop to the ethernet ports, so I know it's not just my TV.
I still show I have a wifi connection to the router on various laptops, but that lack of connection from the router to the DSL obviously prevents me from accessing the internet.
Is there some dual mode wired/wifi setting I've missed?
Thanks in advance,
Pam
Message 1 of 3
jlewter
Guide
Re: WNDR3700v3 having problems connecting both wireless and wired
There is nothing to tie those things together in that way.
I know it can be tiresome to try and find out what is causing a fault, but perhaps it only appears to be happening like this?.. Turn off wifi and see if the wired devices will work on their own with the router.
Message 2 of 3
jmizoguchi
Virtuoso
make sure that TV is hooked up behind the 3700 and NOT using any DSL authentication of any on TV side
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 3
Discussion stats
  • 2 replies
  • 4222 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
