- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR3700v4: Can I Use Same SSID On 2.4 and 5.0?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Likely this has been asked before, but i can't find it. Apologies about the repeat...
I have an old WNDR3700v4. I would like to use the same SSID and password for the 2.4 and 5.0 bands. Would it be OK for me to do this?
I think that modern routers allow this through a feature called "SmartConnect," but I don't see that in the manual of this old router.
May I simply enter the same SSID and password in the router setup screen?
Thanks,
Allen
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@AllenCohn wrote:Likely this has been asked before, but i can't find it. Apologies about the repeat...
Thanks,
Allen
You can use the same ssid. its not the same as smart connect as smart connect does band steering. Meaning it moves a device from 2.4ghz to 5ghz based off bandwidth/distance needs. You might have a few issues with older/single band devices while setting up connections to the network. there's also a few other pro's/cons.
http://blog.luxul.com/2018/06/01/should-i-name-my-2-4ghz-5ghz-wireless-networks-the-same/
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks,
Allen
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR3700v4: Can I Use Same SSID On 2.4 and 5.0?
Thank you for your thoughtful reply! You solved my problem.
Allen
