Reply
WNDR4000 limiting speeds?!
mharoldson
Follower
My WNDR4000 seems to be limiting the speeds that I subscribe to through my ISP. I used the TCP/IP optimizer through speedguide.net to ensure that my computer has the correct tcp settings, but I'm still only getting a maximum of 60 mbps when I subscribe to 100 mbps. I'm wondering if my computer is just too old, but it does have a Gigabit ethernet adapter and it's directly connected to the router. Is there something I'm missing?
PS, I don't know 100% what I am talking about... I'm just starting to learn this stuff but any help would be very much appreciated.
Thanks!
Message 1 of 4
jmizoguchi
Virtuoso
Re: WNDR4000 limiting speeds?!
not sure if 4000 has less WAN-LAN throughput spec but ask support on this model what is the WAN-LAN throughput spec
use portal- my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
realKHz
isn't the WNDR4000 just a router, rather than a modem/router?
could it be the modem you are using that is hampering your speed.
like you, i'm not 100% i know what i'm talking about, ever!
Message 3 of 4
jmizoguchi
Virtuoso
4000 is router indeed.
in most cases newer unit can handle 100Mbps on WAN-LAN throughput.
also speed test should be used with pc wired the router to insure avoid latency etc on wireless connectivity.
other issues can be because broadband modem/router and wndr4000 is not setup correctly can/may cause some issues.
see router setup on my sig below to check
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2680 views
  • 0 kudos
  • 3 in conversation
Announcements
