Reply
WNDR4000 problem STB over WiFi
Tomas303
Well, that's won the miracle called WNDR4000, and was a winner JWNR2000 / as arranged: with JWNR2000 via w wifi adapter to stream WNCE2001 with him on the LAN for the STB (Beeline Russia) shows all the channels and HD and etc. But one day or then every day at a load of torrents, and connect another pair of WiFi devices begins to fall off , new devices at the same time do not get an IP address, even bought a Linksys 3000 , Linksys does not wound up, I got the result that after 5 seconds the picture freezes channel view, and it happens with all channels when you switch them, you have 5 seconds and can be switched on and another 5 seconds. So, I thought, and bought WNDR4000 assuming that it will still be working in conjunction with an adapter without problems, BUT! I saw that picture and tighter with the Linksys, 5 seconds and the picture freezes, and another bug problen 2-3 minutes, and falls off Ineternet connection, is connetc after a while, or you can turn right when you click conect in the settings.
The question is basically the same thing you can do to make multicast via WiFi, since he works c JWNR2000 (when not loaded). and whether there are prospects for a firmware update - Schaub works and does not fall off.?
Thank you!
Internet connecton type L2TP
MTU 1460
MRU 1500
MSS 1460
Using STB Motorola VIP 1216
Using WNDR4000 and WNCE2001 adapter for STB
Thank You
p.s. Sorry for my bad english -)
Message 1 of 18
jmizoguchi
Virtuoso
Re: WNDR4000 problem STB over WiFi
not quite sure but JWNR2000 is hooked up to WNCE2001 and WNCE2001 is connected to WNDR4000?
if so you need WN200RTP instead of your jWNR2000/WNCE2001 setups
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 18
Tomas303
i use wnce2001 for connect my STB without lan cable, and its work good vs JWNR2000 , but not wont working vs WNDR4000 screen on TV freezz after 5 seconds /
Message 3 of 18
jmizoguchi
Virtuoso
oh... assuming 4000 is set to se 300Mbps/2.4Ghz and WPA2 encryption or something?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 18
Tomas303
Yes 300Mbps/2.4Ghz
and Yes Wpa2 / Aes encryption
And signal on wnce2001 is like 120-130 Mb
and if i switch chanel on stb , same problem 5 sec - freezz- after switch chanel - 5 sec freezz
so this is not a problem vs signal , this is problem vs bad multicast on 4000 ( i think like this)
Message 5 of 18
jmizoguchi
Virtuoso
you may want to contact support on this.
my.netgear.com
since other model worked well must be something else may causing the issues.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 18
Tomas303
my.netgear.com
Thank you, i will try tomorrow)
Message 7 of 18
jmizoguchi
Virtuoso
give that a shot. you have not connection issues with your setting.
are you using same wireless channel as jwr2000 before you swap it? because issues can be coming from channel interference issues unless you dod not have any other issues with streaming with PC connecting wirelessly to the wndr4000
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 18
Tomas303
All works, but... i change local ip in router like 10.10.10.1 , after i check all settings, and make on igmp proxy !!! (this is for iptv) from shop his come igmp proxy off, and he start work, stb working, but now diffrent problem, after that i check my net speed, and i have 1,2 Mb in and 6 Mb out, but my tarif is 20\20 also Wifi connection unstable, ping minimum 130-145 . So I make off 4000 , connect my old jwnr2000, and wait for new firmware for 4000.
Message 9 of 18
jmizoguchi
Virtuoso
this is just with any wifi devices such as laptop connecting to the 4000 and no with WNCE for ping issues?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 18
Tomas303
this is not from WNCE , speed test i make on PC - connecting in LAN1 port on 4000
WNCE i use vs 4 port comunicator, for smart TV, DUNE HD and STB -))))) if i put only 2 laptop same story also
Message 11 of 18
jmizoguchi
Virtuoso
what is the front of router i hooked put to.. your broadband modem/gateway models
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 12 of 18
Tomas303
Before JWNR200 now WNDR4000 , connection type l2tp , 20\20 Mb in my room from WNCE2001 lan to trendnet 4 port lan communicator connect TV+Dune HD media + STB also in my room X-box use same Wifi and Wii same Wifi -)) around me 16-18 AP , so 2.4 chanels BUSy
Message 13 of 18
jmizoguchi
Virtuoso
actual BROADBAND model.
you listed the routers and extender. MODELS of ISP PROVIDED unit information Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 14 of 18
Tomas303
Sory, maybe i not understand You, in my home comming Lan cable from my internet provider, i connect 2 WAN port in WNDR4000 make in setup l2tp connection type vs login and password, and have internet. Broadband coonection speed 20 Mb. i not use modem or etc for internet connection, only WNDR4000
Message 15 of 18
jmizoguchi
Virtuoso
I see.... I don't think this router will able to put TWO WAN to begin with
only that can do that is using DD-WRT or Tomato third party firmware
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 16 of 18
Tomas303
sory, conect IN WAN port on wndr4000 -)) I find DDWRT for this device, i will try today ) maybe helps
Message 17 of 18
jmizoguchi
Virtuoso
okay.. if that case I would not look DD-WRT yet .
is your WAN on route is getting public IP?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 3763 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
