× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR4300 blinking/flashing power led after long reset
Snu92
I just tried to do a factory reset to a WNDR4300, but I pressed for a long time the reset button, like for 15 seconds; until the power led started flashing really fast, and it is the only led that is actually working..
Thanks in advance
Model: WNDR4300|N750 Wireless Dual Band Gigabit Router
Message 1 of 4
Accepted Solutions
Snu92
Re: WNDR4300 blinking/flashing power led after long reset
Thank you for answering... I connected the router to a pc with ethernet port and it didn't turn on, either the port of the pc or the port in the router. So I asked myself, if the router is completly dead then. And as a final approach I changed the DC adaptor, and the power led light stayed amber.... I did the factory reset again and that was the problem, a bad dc adapter
I hope this could help others.
Regards
Message 4 of 4
All Replies
Snu92
I tried to factory reset again, the router stays the same (Blinking yellow and amber at the same time the power led).... I cant connect my pc via ethernet because It doesn't have ethernet or lan port...
Message 2 of 4
Guru
You could try reloading the firmware via tftp. I'll link to the procedure. You will need an ethernet port to do so. If you don't have a pc/laptop with an ethernet port, you can buy a usb to ethernet adapter.  There's a bunch for reasonable price on online retailers.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Message 3 of 4
Snu92
Regards
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1912 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
