Reply
WNDR4500 Network Map issue
waxace
Follower
On my router, everything works except the network Map feature, It keeps searching but does not display the map. Any ideas??? I have the latest firmware and all. Perhaps re-install the netgear Genie?? HELP!:confused:
Message 1 of 2
Fairytail
Virtuoso
Re: WNDR4500 Network Map issue
You can try to uninstall and reinstall Netgear Genie. If the same problem, check with other computers if will encounter the same issue.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3503 views
  • 0 kudos
  • 2 in conversation
Announcements
