× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WNDR4500 Stopped Working | Power Blinking Green, Internet Solid Amber
nougain
My WNDR4500 Stopped Working for past few weeks. Power LED is Blinking Green and Internet LED is Solid Amber. All other LEDs are dead (2.4 GHz Wifi, 5 GHz Wifi, USB1 and USB2). Ethernet LED glows though if I connect router LAN port to my laptop Ethernet port.
I researched the internet and tried few things but could not succeed. I am given to understand that my firmware is corrupt. Don't know how I can bring it back to functioning.
I tried this: http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the...
Perhaps, I don't know how to access the router now over the wired connection to install the firmware afresh.
Please help
Thanks.
Message 1 of 8
Accepted Solutions
Fairytail
Virtuoso
Re: WNDR4500 Stopped Working | Power Blinking Green, Internet Solid Amber
Message 8 of 8
All Replies
Babylon5
NETGEAR Employee Retired
Have you first of all just tried a factory reset of the router?
In the instructions for firmware recovery did you set a static IP at the computer, and is the computer directly connected to the router? I suggest that when you do this you disconnect the router from the modem or any other network devices other than the computer.
Is the router still within its warranty period?
Message 2 of 8
nougain
YES
COMPUTER IS DIRECTLY CONNECTED WITH THE ROUTER USING A LAN WIRE. I CAN SEE THE CORRESPONDING LED GLOWING. PERHAPS I DON'T KNOW HOW TO SET STATIC IP PART. I TRIED THIS..https://www.dropbox.com/s/7h7yiaa3ze4h1cf/StaticIP.jpg
ALL NETWORK DEVICES CONNECTIONS, MODEM, USBs ARE DISCONNECTED.
NO
Message 3 of 8
nougain
Please help
Message 4 of 8
Babylon5
A couple of points. You seem to have correctly set a static IP for the PCs wired connection, but you should go back to those settings and change the two DNS entries to the router default IP i.e. 192.168.1.1 for both entries. Disable your WiFi while trying the recovery process, it may be trying to connect to the router using the active WiFi connection.
Message 5 of 8
Hardarse
Novice
Hi there, I too am having the exact same problem which occurred just after I upgraded the router software last night.
Can you please advise if there is any course of action I can take?
Basically the router is not recognised by the computer, so unable to run any repair ops. Not even Genie can fix.
Please assist.
Message 6 of 8
Hardarse
Novice
Please assist urgently.
Message 7 of 8
Fairytail
Virtuoso
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 46082 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
