- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNDR4500v2 firmware update failed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Installed update and waited for counter to stop. Could not get a connection. Saw light on router blinking, turned off router, waited 30 seconds then turned router back on. Tried to connect to internet but could not. Reset router to factory default but still could not connect to the internet. Connection attempts to the router failed. Anyone know what my next step would be?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sound advice from @wcalifas831. Here is Netgear's take on it.
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.
- Control Panel
- Programs and Features
- Turn Windows features on or off
- TFTP client - enable
That's probably easier than retrieving software from a website.
TFTP is a "command line" utility. In Windows it runs from a Command Prompt window. Get there with Winkey + R and enter cmd.
To write the firmware to the device you need to type in:
TFTP -i 192.168.1.1 put {firmware}
where {firmware} is the name of the firmware file you retrieved.
Put the firmware in a directory you can get at, and run TFTP from there.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNDR4500v2 firmware update failed
What does the power LED look like?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the bliinking light just the power light blinking? I've unbricked my wndr4500 before using the tftp method. Look on youtube and follow the steps on "how to debrick a router" You'll have to download a program to your computer called tftp2. You'll have to change a few setings on the ethernet adapter (Ip settings) which those videos will show. You'll also need to download whatever firmware you want to load on it from the netgear website under the support section for your specific model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Control Panel
- Mark as New
- Bookmark
- Subscribe
- Permalink
This worked like a champ!!! I appreciate the cmd info and the TFTP was in Win10 as you said. I really appreciate all the responses. I had to wait a while to make sure everything was working with no other problems.
Thanks, again!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it worked out.
Since I posted my response, Netgear has updated the advice on using TFTP in Windows:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Strange grammar, but it has the information.
