- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNR 2200 should I update from V1.0.1.68_RANDOMNTPPORT?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I previously had problems using an NTP server behind this router and Netgear kindly provided me with the subject modified firmware. Can you tell me if the modofication was incorporated into the later formare versions so that it will be safe for me to install the latest firmware?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK - thanks. I'll try that when I get a chance, although it could be a while as I think the file may be on my old machine.
All the best - thanks again.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNR 2200 should I update from V1.0.1.68_RANDOMNTPPORT?
Nothing in the release notes I found mention it. This is not uncommon, they don't list everything. Try it as long as you have a copy of the one they sent you should be able to revert back to it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
