Reply
WNR1000v2 Motorola Bravo
robert95
Novice
Hi:
I am unable to get my Motorola Bravo to connect to the router. Have changed the security types and passwords. The router shows up and the phone says connecting but then gives up.
Any idea where I should go from here ?
Thanks
Message 1 of 2
jmizoguchi
Virtuoso
Re: WNR1000v2 Motorola Bravo
http://att.deviceanywhere.com/MotorolaBravo/tutorials/8025
looks support WEP only.. you need to contact ATT or Motorola on what encryption supported
if WEP only they you have to use 54Mbps (B&G) setting in the router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2267 views
  • 0 kudos
  • 2 in conversation
Announcements
