Reply
WNR2000 Firmware V1.1.3.14GR
cemmer
Follower
Hello Experts,
My wireless router WNR2000 worked well for several years, but now I see since some months a dramatic drop in performance. Speedtest shows me an upload and download rate of 1MB/s on my iphone and I pad while the router is set up for up to 145MB/s. The internet connection is on broadband connected with 20MB/s.
SPI-Firewall deactivated
WPA2-PSK
Any advice what I should do?
Thanks
Chris
Message 1 of 2
Joe_
Apprentice
Re: WNR2000 Firmware V1.1.3.14GR
cemmer wrote:
...but now I see since some months a dramatic drop in performance.
The only things I can think of are:
- More wifi networks springing up in your neighborhood.
- More wifi networks sharing your channel.
- The wifi networks on your channel are quite busy.
- The router's wifi is failing.
So saying, have you:
- Tested with a wired connection and compared the speed? Is it the same low speed?
- Have you noticed more and more wifi networks around you lately?
- Have you tried using a tool like inSSIDer to see what the wifi situation is around you?
Message 2 of 2
Discussion stats
  • 1 reply
  • 4810 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
