Reply
WNR2000V3 Login Access Denied
ifdinc
I have an WNR2000V3 setup and running in my office. I needed to tweak some items so I tried to login with routerlogin.com. It came back with error 401 saying my credentials were not correct (even though it didn't ask for any credentials.) I did a hard reset. I get the same error. It worked fine when I first got the router out of the box...but not now.
I'm stumped. How do I get back into the router to modify settings? I tried the Netgear Genie download - while it got in, the advanced settings were not available.
Message 1 of 10
sabretooth
Apprentice
Re: WNR2000V3 Login Access Denied
Message 2 of 10
ifdinc
No luck. Also tried the IP address. All give the same error.
Message 3 of 10
sabretooth
Apprentice
Hard reset again but pressing and holding the pinhole for 30 seconds then release. Wait 10 seconds and power cycle the router. Now try.
Message 4 of 10
dpetta
I am having the same problem where the hard reset and return to the default username/password of admin/password is not being recognized when I try to log in to the router.
When I first installed, I could access the router but after installing the latest firmware upgrade I no longer can log in. I am running Windows 7.
Please let me know if you have seen something similar and have any suggestion on how I can get back in.
Message 5 of 10
jmizoguchi
Virtuoso
see router reset on my sig below and try again
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 6 of 10
dpetta
That worked!
I think the difference was previously I had the Netgear installation CD in my CD drive and it was going directly to the setup procedure after resetting/rebooting the router. For anyone having a similar problem, make sure that the CD has been removed.
Thanks for the help!
Message 7 of 10
jmizoguchi
Virtuoso
CD is quite useless as all router has router GUI to setup so makes less complicated to have on hand.....Smiley Happy
Enjoy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 10
NMK
Initiate
Initiate
I am havig the same problem. Have reset multiple times and follwed your reset instructions... any ideas????
Message 9 of 10
jmizoguchi
Virtuoso
make sure to look router setup on my sig below and setup is done correctly.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 5257 views
  • 2 kudos
  • 5 in conversation
Announcements
