Reply
WNR3500 - blink codes?
DaveMT
I have a 3500 that's acting up...
What is considered: Power Light Blinks Green Slowly and Continuously
Mine blinks green about once per second
I tried the factory reset, nothing
I tried Netgear Firmware Recovery Utility, and it times out.
Rookie quesiton... should that have been USB connected or through an EtherNet port (which I tried) - it also changed my pc from dhcp to a hardcoded ip to connect
Thanks.. Dave
Message 1 of 6
jmizoguchi
Virtuoso
Re: WNR3500 - blink codes?
sounds like unit are going south. if the unit is still under warranty suggest to go my.netgear.com and contact support.
you have try with firmware recovery and it's failing so I would call support
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 6
DaveMT
Thanks very much.. will do
Message 3 of 6
snorko
How I can obtain Resource CD for VNR3500 I guess V1 since there is nothing after the model number. I guess then it's V1.
Message 4 of 6
Joe_
Apprentice
snorko wrote:
How I can obtain Resource CD for VNR3500...
1) I suppose (hope) you meant WNR3500 and it was just a typo?
2) You will not get a replacement CD if yours is lost, damaged or whatever. However, you do not the CD to set up or perform any function.
Message 5 of 6
jmizoguchi
Virtuoso
here is answer
http://forum1.netgear.com/showthread.php?t=19304
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2742 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
