Reply
WNR3500L Forward setup and works but does not display in GUI
AvalonNYC
Forwarding is setup to several ports and works. But when we go to the Port Forwarding / Port Triggering page, it shows nothing is setup.
If I try to add a port that's already forwarded, it says: "Port conflict with other service. ". Which of course is correct, but it still does not display the list of services forwarded.
This is the second one of these WNR3500L devices I've seen this on.
Rebooting the router does not resolve this.
It is running V1.2.2.44_35.0.53NA.
Has anyone else seen this?
Message 1 of 3
jmizoguchi
Virtuoso
Re: WNR3500L Forward setup and works but does not display in GUI
hard reset the router and try again
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
NoXoZ
You should try reflashing the firmware of your router and yes, do a hard reset as well. It might help if you can use other browsers or another computer.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4216 views
  • 0 kudos
  • 3 in conversation
Announcements
