Reply
WNR3500L GUI Issues after update
Davy12
Follower
I have a WNR3500L Router here are the stats.
Hardware Version WNR3500L
Firmware Version V1.2.2.44_35.0.53NA
GUI Language Version V1.2.2.44_2.1.12.1
After the upgrade I can no longer go to "Attached Devices" when I try it locks up the GUI and I have to restart the router.
Even though the router still works I can not access it unless I unplug it. :confused:
Message 1 of 3
sabretooth
Apprentice
Re: WNR3500L GUI Issues after update
After the upgrade did you hard reset the router and reconfigure it from scratch as per the instructions?
Message 2 of 3
jmizoguchi
Virtuoso
most likely the hard reset will fix the erratic behavior you will seen after flashing firmware and did not hard reset.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4067 views
  • 0 kudos
  • 3 in conversation
Announcements
