Reply
WPN824N Router Problems
asten
Hello,
I bought a Netgear WPN824N router about a year ago. It worked like a charm the first two months or so that I owned it. Then all of sudden I had issues with it. It connects to my internet for about 10 minutes initially whenever I run the setup router thing on routerlogin.net. I live in an apartment complex that has free ethernet. I have the mac addresses of all of my wireless devices and the router itself added to that companies allowed device settings.
Still after ten minutes the router loses connection to the internet. It's not exactly ten minutes everytime. Sometimes it is five minutes, sometimes it is an hour.
Message 1 of 8
jmizoguchi
Virtuoso
Re: WPN824N Router Problems
usually issues can be using your own router behind router that apartment is using.
what is the WAN IP in the router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 8
asten
The router the apartment is using? It comes from a jack in the wall. There isn't a wireless connection provided by them. If it was something like that, wouldn't it have been an issue from the get go? 24.227.222.12
Message 3 of 8
jmizoguchi
Virtuoso
hard reset the router is first thing I would and see
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 8
asten
I've done that.
Message 5 of 8
jmizoguchi
Virtuoso
24.227.222.12 is road runner cable services
if you have PC hooked to outlet , use pc's mac address under basic setting of the router interface
ipconfig /all from command line on pc will show the mac address
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 8
asten
What do you mean? This is what i get from ipconfig all Windows IP Configuration Host Name . . . . . . . . . . . . : MattAsus Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Wireless LAN adapter Wireless Network Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN Physical Address. . . . . . . . . : 00-22-FA-5D-82-C4 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::fc8d:be5c:933b:dda0%12(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Tuesday, October 11, 2011 11:25:30 AM Lease Expires . . . . . . . . . . : Wednesday, October 12, 2011 11:25:30 AM Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 285221626 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-00-3F-FE-00-26-18-8F-91-30 DNS Servers . . . . . . . . . . . : 192.168.1.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : CPE0.mdu Description . . . . . . . . . . . : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) Physical Address. . . . . . . . . : 00-26-18-8F-91-30 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Message 7 of 8
jmizoguchi
Virtuoso
You need to use ethernet adapter's Mac addresss
You are showing wireless information. If you are using cable modem directly with PC then you wouldn't use wireless .
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3259 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
