Reply
WPN824v2 connectivity with Asus HDP-R3 media player
SjaakDraak
Hello,
i just bought an Asus HDP-R3 media player that has the ability to connect with your Wifi network. However there seems to be a problem connecting to the router which is the gateway to the desktop computers on the wireless network. I haven't got any software for the wpn824v2 router, so I can't check which settings are installed for this router. Does anyone know if these two devices are even compatible, or do I need to configure the router settings?
I hope somoene knows what to do, I am not a big computer stuff wizard so it seems.
Thanks in advance,
Message 1 of 5
jmizoguchi
Virtuoso
Re: WPN824v2 connectivity with Asus HDP-R3 media player
Make sure router's wireless setting is using B&G mode and wap,wpa2 encryption
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
SjaakDraak
How do I adjust the router settings? Do I need software for that, because I haven't got any router installation cd to be honest. The router was supplied by the internet provider, and it was plug and play. Anyone know where I can get router software for the wpn824v2. greets
Message 3 of 5
jmizoguchi
Virtuoso
read manual to how to login the router. basic thing procedure in the manual
support.netgear.com and download , read... 5min to find out
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 5
SjaakDraak
Thanks, gonna give it a shot.
Message 5 of 5
Discussion stats
  • 4 replies
  • 2307 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
