- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WPS process is in progress and won't let me enable wireless
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
Problem with a Nighthawk x10 Model R90000 with the newest firmware (V1.0.5.38).
I'm at a loss. It appears the WPS Wizard is running according to the router, but according to my devices it isn't. It also appears wifi broadcast is off.
- Cycling power on the router does nothing.
- Tried the hold-down-button for 30 seconds that Netgear's site suggests. Doesn't do a thing. The wifi and WPS button lights were off and never came on.
- Running and canceling the WPS wizard was not possible since the wizard's button was disabled and unclickable.
- Managed to get the wifi and WPS lights back on by turning off the wifi via the button on the back of the router, then holding it on for ~10s. Still didn't fix the problem.
And wired LAN still works fine.
Any help would be appreciated. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WPS process is in progress and won't let me enable wireless
Try a factory reset and setup from scratch. Press the reset button for 10 seconds then release. Walk thru the setup wizard.
Netgear has set up a community forum specifically for the NightHawk Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset and setup from scratch on the router?
@glennf0908 wrote:
Hi.
And wired LAN still works fine.Any help would be appreciated. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@glennf0908 wrote:
I tried a factory reset and rebuilt the wireless setting, the WPS problem persisted.
Does this mean that you are trying to use WPS and it doesn't work?
Is there still an entry for "WPS Settings" in the browser graphical user interface (GUI)?
ADVANCED > Advanced Setup > Wireless Settings.
Maybe this is one of the features removed in recent firmware on security grounds.
I just bought a linksys router, more expensive but at least I can get tech support and don’t need a computer Science degree.
Does this mean that you have abandoned the R9000?
.... Apple battery much?
I'll bite. What does that mean?
