× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
What am I doing wrong? Opening a port on my wireless router.
elloellothere
Hi!
I'm trying to open a port on my router, so my home network can be access externally.
What am I doing wrong with the setup? I've done the setups in instructions, but my port is still closed.
Example of what I've done :
Added a firewall rule to port 445 : http://oi68.tinypic.com/14xfe5h.jpg
Port Forwarding setup : http://oi63.tinypic.com/2hfi3aw.jpg
But port is still closed : http://oi63.tinypic.com/2n0ioma.jpg
Message 1 of 3
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: What am I doing wrong? Opening a port on my wireless router.
Welcome to the community, @elloellothere
What's the exact model number and version of your router?
Do you have the latest firmware installed on the router?
Did you try factory reset?
When you bypass the router, will this port work?
Just want to make sure that your ISP is not blocking such port.
Looking forward to your response.
Message 2 of 3
All Replies
ElaineM
Message 2 of 3
elloellothere
ISP was blocking the port! /thank you 🙂
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3379 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
