Reply
Why 2 different firmwares for R6220 AC1200-Smart WiFi Router?
S-Warren
Tutor
I managed to download from Netgear site two different firmware versions for the same product which is the R6220 AC1200 Smart Wifi Router with external antennas.  One of them is "R6220.aspx" and the other is "R6220_FW_V1.1.0.31_1.0.1.zip".
My question is which one of the above should I use to update the firmware on my product which is currently v1.0.0.17.
Message 1 of 4
Accepted Solutions
netwrks
Master
Re: Why 2 different firmwares for R6220 AC1200-Smart WiFi Router?
This looks to be the current version with directions, filename, etc..
Message 2 of 4
All Replies
netwrks
Master
Message 2 of 4
S-Warren
Tutor
I'm hoping that updating from 1.0.0.17 to 1.0.0.31 will fix some issues I'm having with Netgear genie misreporting devices that are attached. It keeps saying my Blu-ray player is attached even when the unit is unplugged from the power outlet. Guess I'll have to update and cross my fingers, lol.
Message 3 of 4
Maverick4396
It might fix some issues, but it will likely add different ones.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3011 views
  • 0 kudos
  • 3 in conversation
Announcements
