- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wi-fi won't work! Please help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
My wi-fi won't work. Netgear Genie keeps saying it isn't enabled. I've rebooted the router, the modem, and the computer. I've checked that the wi-fi button on the router is on (tried turning off and back on). I've checked that my wireless adapter is enabled - tried disabling and then enabling. I've updated the drivers for the wireless adapter. I've updated the drivers for the router. I really don't have the money to just buy a new router when it may not work either. I've been having trouble with the wi-fi since the beginning - constant issues, but it's been two days and I'm ready to scream. Can anyone help?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wi-fi won't work! Please help!
When you say reset what kind of reset did you perform. You should do a hard reset by pressing the reset pinhole with a paper clip for 30 seconds while the router is on. That will set it back to defaults and you will start it from scratch just like it was when it was new. Did you try that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you tell us what the Netgear router is? The model number?
- Mark as New
- Bookmark
- Subscribe
- Permalink
