Reply
WiFi Network
gaemond4
WiFi Network
how do I remove a device from my network?
Message 1 of 6
Retired_Member
Not applicable
Re: WiFi Network
change the passphrase
Message 2 of 6
TheEther
Guru
Re: WiFi Network
Are you trying to kick someone off of your Wi-Fi network?  Some routers have a feature called Access Control that will allow you to whitelist specific devices and deny access to all others.  But given that this security feature is easily bypassed, I don't recommend using it.
The only other alternative is to change the Wi-Fi password.  Yes, it's a pain, but it's the only guaranteed way of kicking out a device.
Message 3 of 6
Re: WiFi Network
Given how vague the original question is, can I also throw in the suggestion that you wield wire cutters? Just snip the wire that joins the device to the network.
Other than that, as people say, what network? what device?
Could be anything.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 6
gaemond4
Re: WiFi Network
I connected my desktop computer to my Netgear router (wirelessly). It is already connected to the router with a wire. I disconnected the wireless connection to my desktop. The network map still shows a ghost image or the wireless connection to my desktop. How can I remove this Unused connection?
Message 5 of 6
Retired_Member
Not applicable
Re: WiFi Network
try disabling the WIFI card
Message 6 of 6
Discussion stats
  • 5 replies
  • 3643 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
