Reply
WiFi connection
pheppolette
WiFi connection
I live in a rural area with no WiFi service. Can I use a Smart Bro portable WiFi with Ethernet out to connect to the Orbi router?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: WiFi connection
Potentially yes. Not sure what specific smart bro device you're using but if it has an integrated router (more than likely) you'll probably need to put the orbi in AP mode or you'll have a double nat issue.
there's a bunch of results on connecting a smart bro hotspot to a router and they look to be successful.
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 4
pheppolette
Re: WiFi connection
Thanks for timely reply. Excuse my ignorance but how do I put the Orbi in AP mode
Message 3 of 4
Guru
Re: WiFi connection
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 302 views
  • 0 kudos
  • 2 in conversation
Announcements
