- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to figure out why my WiFi is slow and cuts out, even with the laptop two feet from the access point router (more with some websites than others) - not really different with WiFi connection to main router (Arris TG862G Gateway - kind of locked in to Comcast choice because of the telephone port for Comcast Voice). I am thinking about getting something newer for the access point to replace the WNR2000. Perhaps AC1200 or Nighthawk AC1900 Dual Band. Should I have a vast difference in speed and connection using WiFi versus ethernet wired? (I am almost always on a computer wired directly on ethernet. Maybe I am spoiled.) Is my WNR200 just too old technology?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @xian,
1. What is your subscription speed from your ISP?
2. Are you getting that speed while wired to the Arris gateway?
3. What is the WiFi speed that you are getting from the Arris gateway?
4. What is the speed that you are getting wired and via WiFi through the NETGEAR router?
5. Wired/Ethernet connection will provide a better connection most of the time.
6. You will need to consider several things when upgrading and/or connecting via wireless. Network environment, subscription speed, and devices that will connect (compatibility) are some of the first things you need to look into.
Regards.
Dexter
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @xian,
Regards.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi connectivity
Seems like the problem must be something relative to my laptop. No one else has encountered the problem. Anyway, I ended up running an ethernet wire off the access point to a nearby desk for blazing fast internet, when I really want fast. Good enough that I haven't had time to check all the speeds.
