Reply
Highlighted
WiFi signal stops
When my imac sleeps or shuts down the signal stops and I pull the  rev=boot the router to ge a signal.  This is new the router has been working properly for a few years
Message 1 of 4
Highlighted
NETGEAR Employee Retired
Re: WiFi signal stops
Hi @Dcm,
Welcome to the community!
Do you happen to see if you lose the wireless light on the router when your iMac sleeps? Can you still see the wireless name of your network when it happens? Will you get the same result on all other wireless devices that connects to the router or this is the only computer affected? If this is the only computer affected you may want to check the sleep settings on this particular computer. If all computers and other wireless devices are affected, let us know the model number & version of your router. You may also want to change the channel on your router for the meantime to see if this helps. Try to play around with channels 1,6 & 11.
Let us know what happens.
ElaineM
NETGEAR Community Team
Message 2 of 4
Highlighted
I have competely set up the router from scartch and it seems to be working fine at this time.
Thanks for the reply
Message 3 of 4
Highlighted
@Dcm You are very welcome. Let us know if you need further help.
ElaineM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2323 views
  • 0 kudos
  • 2 in conversation
Announcements
