- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Windstream says router is interfering with dsl modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then, your Speedstream is functioning as a router. You will have to pick one of the two options I provided in my first reply.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Windstream says router is interfering with dsl modem
It looks like your Speedstream 4200 is actually a combination modem and router. Most home networks should only have one device functioning as a router.
You should decide whether you want to use the router in the Speedstream or the router in the WNR1000.
- To use the Speedstream as a router, you will want to set up the WNR1000 as an Access Point. Log into the WNR1000, disable the DHCP server and connect one of the WNR1000 LAN ports to the Speedstream LAN port.
- To use the WNR1000 as a router, log into the Speedstream and enable bridge mode. Connect the WNR1000 WAN port to Speedstream LAN port. Note, you may lose the ability to log into the Speedstream once it's in bridge mode. If you ever wish to disable bridge mode, you will have to reset it to factory defaults using the reset button (push for 4 seconds, according to the manual).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
According to the manual, the Speedstream 4200 is a combination DSL modem and router.
Can you log into the WNR1000? Go to the Basic Settings page and look at the IP address. If it starts with either 10.x.y.z or 192.168.y.z, then your Speedstream is definitely running in router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your ISP uses PPP to log into their Internet service, then you may have had to transfer the PPP settings from the modem to the router. Hopefully, you made note of them. If not, call your ISP and ask them for help.
Or you can try resetting the modem to factory defaults to return it to router mode. It may be easier to set up the WNR1000 as an AP. This way you don't touch your Speedstream.
