Reply
Wndr3400 v2
Smack
Wndr3400 v2
Having issues with my wireless. Has been working fine until I got home from work today. The wireless had been turned off somehow, so I turned it back on. All my wireless devices see the router, will try to connect and then immediately disconnect. Im using WPA2-PSK[AES] security. If I turn off security I can connect but if I put in a password it will not connect. Yes ive put in very simple passcodes to make sure all devices had the correct code but no luck so far.
Message 1 of 6
Jack_
Re: Wndr3400 v2
Try each one of the 3 security settings available:
WPA
WPA2
WPA + WPA2
Also make sure your browser's cache has been cleared before attempting this.
Message 2 of 6
sabretooth
Apprentice
Re: Wndr3400 v2
I had this problem. Resolved by reflashing the firmware with the same or newest version. When done, power cycled the router. Then reconfigured from scratch. Works fine.
Message 3 of 6
jmizoguchi
Virtuoso
Re: Wndr3400 v2
try delete the existing wireless profile on you pc and any devices first.
then try scan again and type the updated passphrase instead of trying to type on existing wireless profile.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 4 of 6
Smack
Re: Wndr3400 v2
Thanks all for you input. Not much on this networking stuff so after debating with myself I decided to just reset the router to factory settings and start from scratch. Seems to have fixed the problem, still not sure what caused it that is still bugs me.
Message 5 of 6
jmizoguchi
Virtuoso
Re: Wndr3400 v2
On what ground. If you don't share how it works hard to tell it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 6
Discussion stats
  • 5 replies
  • 2802 views
  • 0 kudos
  • 4 in conversation
Announcements
