Reply
Wndr3400v3
HDEVIL
Wndr3400v3
I'm assuming the USB port can be used to connect a range extender, if so what is the best bang for buck - need coverage from shop to an outside trailer (double wide) - can already get signal putting router outside, but would prefer a booster or antenna to get better signal strength - what to you suggest?
Message 1 of 4
Re: Wndr3400v3
@HDEVIL wrote:
I'm assuming the USB port can be used to connect a range extender...
The USB ports on most Netgear routers are for printers or for storage devices. That is what it says in the manual for your device.
I have never seen any suggestion that you can use USB for a (wifi?) range extender. That is usually in the hands of a LAN port, or the router's own wifi.
What are you trying to do?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
HDEVIL
Re: Wndr3400v3
What can I use to extend or boost signal then for this router?
Message 3 of 4
ElaineM
NETGEAR Employee Retired
Re: Wndr3400v3
There are different ways on how to extend the signal.
You may want to see our Range Extenders or Powerline adapters.
https://www.youtube.com/watch?v=z-SlfwsbbqA
https://www.youtube.com/watch?v=u46Y57-xS1Q
ElaineM
NETGEAR Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2251 views
  • 0 kudos
  • 3 in conversation
Announcements
