Reply
Wndr4300 crashing daily
constancevan
Follower
my internet connection crashes daily multiple times per day i understand their is a firmware download that can fix this problem (WNDR 4300 Dropping internet connection daily! from reading some of the communities post )    is their away to get the  software I  cannot afford to pay 50.00 for tech support I have a home network which is share with my neighbor i own the  network but she use it and we share the cost so it often has different device connected i use it for  home business purposes and i cannot get stuff done because of  it failing  i reboot router and it works for a while but after booting the gateway has to be reset or rebooted also
thank you
Model: JR6150|AC750 Wireless Dual Band Gigabit Router,WNDR4300|N750 Wireless Dual Band Gigabit Router
Message 1 of 2
wcalifas831
Prodigy
Re: Wndr4300 crashing daily
Did you check the netgear website to see if there's a firmware upgrade you can do? Also, when you have to reset it is it after its being used alot?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2429 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
