Reply
Wont Connect
Remixer
Wont Connect
Extender all it does is flash all the lights on and off, cant reach it by ip address. Already hardwired it to the computer and nothing. No connection and does not pop up on my wifi either.
Help.
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 4
Guru
Re: Wont Connect
Have you tried pushing and holding reset for 7-15 seconds while powered on?
Also, the default ip address if its not setup is 192.168.1.250, have you tried this address?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
Remixer
Re: Wont Connect
Several Times to both suggestions. Computer doesnt see it when you go straight with the IP Address.   Just continues to blink all lights on and off.
Message 3 of 4
Guru
Re: Wont Connect
you could try recovering it via tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 328 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
