Reply
Wrong firmware update, unable to reset
cdemaio
Follower
Router: WGT624v3
Problem: I was having several issues with the router's wireless dropping internet activity and forcing me to continually reset it, so I went to upgrade the firmware, and looking at the bottom of the router where it states "WGT624 (v2.1)" I assumed it meant that the hardware version was also 2. I uploaded the firmware for the WGT624v2 router and now I am unable to reset the firmware and upload the WGT624v3 firmware. I do not have access to the cd that came with the router, hence I cannot use the firmware recovery ultility. If there is any other way of reseting the firmware or possibly accessing just that ultility it would be appreciated.
Thanks,
Chris
Message 1 of 2
jmizoguchi
Virtuoso
Re: Wrong firmware update, unable to reset
You have brick the unit loading v3 on v2 router , should not have loaded but here
http://forum1.netgear.com/showthread.php?t=30453
Try TFTP method and if still fails then you are looking to replace the router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Discussion stats
  • 1 reply
  • 6651 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
