- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
X box One double Nat from ATT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rural community. LB 1120 Netgear modem already set to bridge mode. Linked to Tenda AC6 router. Internet works fine. ATT sim card on IPv4. No 6 available. Tried a VPN, didn't work. Tried to set a static IP. No luck.
Only issue is that Xbox one S will not allow multiplay owing to Double NAT detected and Strict NAT setting.
Have been told that I cannot get rid of thr double NAT as that is what ATT are putting out in the first place. Which means that xbox is worthless. Surely there has to be a way to open a NAT. Help, please
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X box One double Nat from ATT
> [...] LB 1120 Netgear modem already set to bridge mode. Linked to
> Tenda AC6 router. [...]
What is the IP address of the WAN/Internet interface on the Tenda
AC6 (I'd guess: Internet Settings > IP Address)? Plug that address
into the form at: https://whois.arin.net/ . Is it a public address or a
private address? If it's not a public IP address, and the LB1120 really
is in bridge mode, then there's nothing which you can do about it from
your end.
> ATT are putting out in the first place. [...]
"told" by whom? I'd trust no one, but see above for a way to be
sure.
> [...] Surely there has to be a way to open a NAT. [...]
Choose a different ISP? Complain to AT&T?
Possibly interesting:
