Reply
NikonNrse
XBOX LIVE wired connection
Ok...extremely frustrated here. I had a working dlink router. Xbox live wired in, no issues. ISP DHCP...When I switched to the 4500, I cannot connect to the xbox via wired at all. THe port it is wired to wont even light up. What is weird is that I CAN connect wirelessly, but on my xbox...i dont want that.
I've followed every suggestion and am pulling my hair out. Everything else I try works...so I know its not the port. It is odd.
I removed the netgear and pt the dlink back on and everything works..I just wanted the speed of the netgear.
Message 1 of 10
jmizoguchi
Virtuoso
Re: XBOX LIVE wired connection
try static IP on xbox outside the DHCP range of the 4500(you will need to adjust DJCP range)
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 10
NikonNrse
OK...in a fit..I pulled all the wires, Love the feel of insulation on my face BTW.
The cord was sliced just a bit. Guess the net gear is more sensitive than the dlink to it.
NOw my next issue is the nat setting...UPNP is enabled...get moderate or strict on all xboxes in house....suggestions?
Message 3 of 10
jmizoguchi
Virtuoso
make sure WAN/internet port of the 4500 has PUBLIC IP (ISP release IP0
see router setup on my sig below. make sure broadband and router is setup correctly done
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 10
NikonNrse
I have service that comes from a wire into my house to my modem, I dont have a secondary modem..just the net gear. Im a bit confused.
Message 5 of 10
jmizoguchi
Virtuoso
Then open the ports
Go to portforward.com
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 10
carralo1
I have my xbox360 wired to a WNDR4500 in my central panel. UPnP enabled and my xbox360 on DHCP IP. 4500 opens and closes ports without issue for the 360.
running
Firmware Version
V1.0.0.70_1.0.18
Message 7 of 10
the_tags
I would make sure you have the latest firmware and then do a 30/30/30 reset of your router. This opened up my NAT.
Message 8 of 10
dw17dw17
30/30/30 reset ?
Message 9 of 10
jmizoguchi
Virtuoso
See router reset on my sig below for proper reset procedure
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3685 views
  • 0 kudos
  • 5 in conversation
Announcements
