Reply
cannot connect second extender ac750 to network
davenicsnr
Tried to connect with simple wps set up but failed.
So followed previous extender connection instructions and used ethernet cable between extender & laptop.
First effort failed part way through process - network security key not recognised.
So did a factory reset and started again. Gave extender new ssid for 2.4 & 5 Ghz band and completed setup
This time all seemed to go well but when connecting extender close  to the router to test connectivity same problem - no connection with wps? The router and wifi connection is working fine.
So did another factory reset to try again but this time no access to new extender set up gene?
Figured if I cleared everything I'd done out of memory and started again I might have some success.
Is there data that needs to be cleared out elsewhere?
Can someone advise how I get back into the gene.
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 14
Accepted Solutions
Guru
Re: cannot connect second extender ac750 to network
If you didn't reset the original it should connect. But you can always try rerunning setup on it
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 14 of 14
All Replies
Guru
You're setting up a 2nd one?
Did you shut off the 1st one during setup?
What router are you connecting it to?
Message 2 of 14
davenicsnr
Yes setting up a second extender. N300 already installed on 1st floor
No I didnt shut N300 down
Vodafone broadband wifi hub model THG3000
Message 3 of 14
Guru
try shutting off the 1st one while doing setup on the 2nd. Then once its setup, power the first back on
Message 4 of 14
davenicsnr
Shut off ist floor extender but didnt make any difference.
I did finally connect to the set up gene with ethernet cable and was able to connect laptop and other devices to the new extender but after several attempts. Authentification problems shown on mobiles.
However the extender wps led is not turning on so I assume I have no security? Have I missed something in the set up?
Message 5 of 14
Guru
You were able to hardwire into it and go through the setup using the installation assistant?
Is that correct?
What authentication problems are you getting?
Message 6 of 14
davenicsnr
yes I connected an ethernet cable.
1st floor extender N300 is showing authentification error. New ac750 extender no wps but can access internet.
Message 7 of 14
Guru
what authentication error?
Did you try a different browser/pc for setup?
Message 8 of 14
davenicsnr
All I can tell you is authentification error shows on both extenders - it doesnt give a description of what it meanes. The router maybe doesnt like 2 extenders
Also problem seems to be linked with 2.4GHz band.
I can connect to the internet when 5GHz band is selected on ac750 - 0DF9A3_5GEXT
I used the same browser ms edge for the set up.
Is it possible by having to revisit the gene several times something could be corrupted?
Are you able to check from your end
Can everything be cleaned out and started again?
Message 9 of 14
Guru
Looks like you're not the only one with issues adding extenders to that router.
https://forum.vodafone.co.uk/t5/Other-broadband-queries/THG3000-Router-Setup-to-TP-Link-RE305-Extend...
Message 10 of 14
Guru
If you search their forums, there's a bunch of issues with adding extenders to that router.
Message 11 of 14
davenicsnr
I see what you mean. Seems this router is the problem. It explains why I've been getting so many strange things occuring.
The only thing we now know is that only one extender will work on the THG3000
So now its a matter of returning things back to the way they were. N300 or AC750 on the 1st floor
Many thanks for your time & help. Pity we could'nt get a solution
Message 12 of 14
davenicsnr
Reconnected original extender N300 on 1st floor but could not connect to router. Is it possible I need to programme again after trying to set up ac750?
I had not removed the N300 initialy when trying to set up ac750. Could this be the problem? Could one have effected the other.
Spent the last 2hrs on the phone with vodafone support. They advise router is ok following tests.
They are calling me back in 2hrs after I have contacted you for advice
Message 13 of 14
Guru
Message 14 of 14
Discussion stats
  • 13 replies
  • 1712 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
