Reply
convert DG834N to repeater with firmware
PotemkinSunJuan
Are there any Netgear wireless repeater firmwares that I can apply to my useless old DG 834N?
I want a functioning repeater that supports WPA2-PSK [AES], like my marvellous WN2000RPT, and was wondering if the chipset in the 834N could do the job.
Message 1 of 5
Scubbie
Apprentice
Re: convert DG834N to repeater with firmware
Due to licensing issues, you can only do this using no encryption or WEP.
You could look at using a custom firmware though.
Message 2 of 5
PotemkinSunJuan
Ok - thanks for the advice. I've yet to find any 3rd party firmware that works with this thing. DGteam does some, but it just bricks the router. I guess it was useless as a router, and isn't much use even as a paperweight. A woeful device...
Like my DGND3700 though....
Message 3 of 5
PotemkinSunJuan
Thanks for the advice. This thing always was useless...
Only DGteam does custom firmware for it, as far as I can tell, and that just bricks the device... oh well..
Message 4 of 5
jmizoguchi
Virtuoso
I hears those DG firmware is terrible.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3169 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
