× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
dgnd3700v2
hannahhol
dgnd3700v2
Can i uses this router with comcast voice services?
Model: DGND3700v2|N600 WIRELESS DUAL BAND GIGABIT ADSL2+ MODEM ROUTER
Message 1 of 5
Accepted Solutions
antinode
Guru
Re: dgnd3700v2
> I have a cable model [...]
   A cable _modem_?  Not a very detailed description of anything.
> [...] everything works but the phone.
> I was trying to find out if I could use there ADSL filter to correct
> the issue
   That makes no sense.
>    Ask Comcast?
   Did you?  I suspect that you need a voice-capable cable modem.
Message 4 of 5
All Replies
antinode
Guru
Re: dgnd3700v2
   Ask Comcast?
   Can you use a DSL modem with a cable-TV-type ISP?  I'd guess not.
   You might be able to do something with the router section of a
DGND3700v2, but if you need a cable modem, then you need more than a DSL
modem+router.
Message 2 of 5
hannahhol
Re: dgnd3700v2
I have a cable model so everything works but  the phone. I was trying to find out if I could use there ADSL filter to correct the issue
Message 3 of 5
antinode
Guru
Re: dgnd3700v2
> the issue
>    Ask Comcast?
Message 4 of 5
hannahhol
Re: dgnd3700v2
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1517 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
