Fasterisgood's avatar
Fasterisgood
easyshare
Easyshare links are not working.  Is there a replacment?  trying to connect to wndr6300 and share on network
    • Fasterisgood's avatar
      Fasterisgood
      how do i use easy share option to use router for network sharing?  Links are all disabled.  would like to password encrypt and share the storage on out network.  Is there a work arounf for none cloud hard drive?
      • michaelkenward's avatar
        michaelkenward
        What is easy share? (See above.) A quick search of nearly 1000 Netgear documents finds no mention of this idea.
        Do you mean ReadySHARE?
        If so, visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware.
        Check the section in the manual Accessing and Configuring a USB Storage Device.
        You may have done this already. I can't tell from your message.
